To Charge or not to Charge?
Old Feb 27, 2007 | 01:38 AM
etep31's Avatar
etep31
Default To Charge or not to Charge?
for those of you who do have a supercharger/procharger/turbo charger:
1.) What do you like/dislike about it?
2.) How much was it?
3.) Where did you get it?
and...
4.) Did you have it professionally installed?
Thanks for the advice in advance!
Old Feb 27, 2007 | 02:07 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: To Charge or not to Charge?
Hmmm..............let's see, sixers with an S/C that frequently post on this forum...................1, sixers with S/Cs that are hit or miss on posting, 3, maybe 4 at best.
I say this, look around, even ebay, a lot of places sell S/Cs but the V6 version is a little harder to find but not impossible. I will say this much, I would try to get one that can be made, or is an intercooled system. Some oil cooled systems, like Vortec and Paxton tap into the oil pan to help lube and cool the S/C. Only problem is that if you get on it a lot and your oil gets too hot you can run the risk of damaging the S/C, it has happened before, somebody in the 5.0L forum had it happen with a Paxton, never heardof the problem with Vortec, but it seems to be a problem with Paxton,where as intercooled systems are always cool and can allow you to tune for more PSI boostif you wish, however they are pricier.
Old Feb 27, 2007 | 02:10 AM
Xemeth's Avatar
Xemeth
Supercharger: www.vmptuning.com
Turbocharger: www.tmaturbo.com
'Nuff said!
Old Feb 27, 2007 | 02:33 AM
etep31's Avatar
etep31
i should have said it's for an '03 but still i need more ideas on places, prices etc. what about eaton?
Old Feb 27, 2007 | 02:41 AM
Xemeth's Avatar
Xemeth
I don't think eaton makes one for a six. Actually, the only eatons I know of on Stangs are the M90 for a single port six and the M112 on the 03/04 Cobras. To make the M90 fit you'd have to switch to a single port, so it isn't really worth it, and it's more trouble than it's worth to make an M112 unless you're confident enough to do a lot of custom fabrication work yourself.
Old Feb 27, 2007 | 02:42 AM
jthorn9's Avatar
jthorn9
The Godfather
Yea, count out Eaton if you own a 99+.
Old Feb 27, 2007 | 03:18 AM
etep31's Avatar
etep31
ok yay or nay on the eaton 90 or an eaton at all?
Old Feb 27, 2007 | 03:43 AM
jthorn9's Avatar
jthorn9
The Godfather
NAY, it's not worth the hassel!!!!!!!!!!!!!!!!!
Old Feb 27, 2007 | 09:55 AM
nanaki's Avatar
nanaki
Retired MF Moderator
you can run non-cooled just fine. i ran non-cooled over a year with no problems. it's all in the tune. running cooled doesn't necessarily let you run more boost either.
Old Feb 27, 2007 | 10:26 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
Procharger. cons: Bad history of bad seals. Pros: intercooled
Vortech. Cons: need to tap oil pan, no intercooled kit.Pros: super reliable
Eaton. Cons: won't work on 99+, super heat charge air. Pros: instant boost
Turbo. Cons: $$$$. Pros: efficient, most power, easy to up boost.
i would go turbo if i didn't already have a Vortech.
