i have a 1980 convetible it had a 200cid inline 6 in it and i was wondering if the trans with it is a C-4 and if it is will it hold up to a 302 if i get a differant bellhouseing??
just a shot in the dark, they made a c5 which was kind of odd ball and a little weaker but it had better cooling or something. i'd venture to guess that's what you have.
I would say this much, it would be much cheaper to go out and get a car with a 5.0 then to do the swap, becasue there's a lot more that needs to be done then just swaping engines.
k member, driveshaft (maybe), rear, trans, crossmember, bellhousing, engine&mounts, throttle cable, fuel lines, non computer distributor, maybe radiator...it's not that damn much when you're not messing with fuel injection. then you get into the brakes and suspension debate, but that's preference.
