stroker kit 4.2
I may be getting a stroker for cheap from a guy i work with my thoughts are will my stock fuel pump/injecters be ok running the additional power also should I invest in a new throttle body??
what kind of increases could i expect from this stroker??
Edit: Forgot to mention its forged parts and is 4.2
What guts does it have? What cam? Heads? Intakes?
Stock fuel system will more than likely be fine. It would take a pretty over the top N/A 4.2L to need major fuel upgrades. Don't waste your time on a TB. They aren't worth it.
ORIGINAL: johnt2k7
why is everyone buying stroker kits cant u just go to the junk yaed and grab a f150 cank and have the same stroke with out the new spistons and rods and at a hell of a less cost
Becauase "MOST" strokers are forged kits.
Your stock fuel system should be OK as long as you don't do any other mods. But I say while you're at it, swap the cam, port the intake, port the heads or buy high flow heads, and then upgrade the fuel system, because all of that has to come off when doing a stroker swap, you also need to hone and balance the engine in accordance to the specs of the stroker kit.
