Turbo question
Old Mar 5, 2007 | 05:16 PM
mustang961222's Avatar
mustang961222
Default Turbo question
I have a 1996 mustang with 115K miles on it would it be too old for me to get a turbocharger or a supercharger?
Old Mar 5, 2007 | 05:47 PM
02MustangV6DD's Avatar
02MustangV6DD
Default RE: Turbo question
Nope
Old Mar 5, 2007 | 05:50 PM
02StangStud's Avatar
02StangStud
I wouldnt do it either
WhitePony02's Avatar
WhitePony02
For me that would be too many miles to put a power adder on, but you can still do it.
Old Mar 5, 2007 | 06:01 PM
mustang961222
ok i had another question how loud would my car get if i got a down pipe that went all the way out so my axhaust system would be just 2 tubes??
Old Mar 5, 2007 | 06:06 PM
02MustangV6DD
I meant it would be fine. The pipes would be too noisy. My buddys putting a turbo on his mustang right now as i type, its got about 167k
Old Mar 5, 2007 | 07:12 PM
johnt2k7's Avatar
johnt2k7
it depends on how the car was maintained if it had regular oil changes and stuff like that and it has not had the **** run out of it
Old Mar 5, 2007 | 07:50 PM
cobra232's Avatar
cobra232
even with good compression the rod and main bearings may have alot of wear on them. you could always get a 97 or 98 junkyard engine with half the miles on it for only $400. you would be fine then
also early 96's had the old heads like the 94-95 which were prone to headgasket failure. they changed sometime in 96 but no one can exactly say when.
115K on the clock either rebuild it or drop a lower junkyard engine in it first before you add a poweradder. no sense doing all that work for the rod bearings to crap out 2,000 miles later
Old Mar 5, 2007 | 07:54 PM
mvr's Avatar
mvr
if your that worried about the miles, sell it and get a lower milage one. new edge v6's arnt that expensive anymore at all.
Old Mar 5, 2007 | 09:39 PM
mustang961222
ORIGINAL: mvr
its got alot of miles i dont think i could get much,,,
