HOW TO SEAFOAM
Old Mar 12, 2007 | 04:12 PM
flash20's Avatar
flash20
Default HOW TO SEAFOAM
ok does any1 know how to it?
Old Mar 12, 2007 | 04:53 PM
flash20's Avatar
flash20
Default RE: HOW TO SEAFOAM
bump
Old Mar 12, 2007 | 05:00 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
pull a vaccum hose on the intake, and suck the stuff through there, unless of course, you messed up and brought the aerosol kind. lol.
You'll need to manually operate the throttle to keep the motor running as it pulls it in since, it does make it drop in idle a bit. just let it pull in a little at a time, don't try to over-do it.
Ryan
mcccop_04's Avatar
mcccop_04
pull your pcv valve and let the car suck about a 1/3 of the bottle while its running, put a 1/3 in the oil (change it in about a 100 miles), then put the last 1/3 in the gas tank. turn car off, wait 10 minutes or so and start her up and enjoy the show
Old Mar 12, 2007 | 05:02 PM
flash20's Avatar
flash20
r u sure about the engine oil?
Old Mar 12, 2007 | 05:19 PM
mcccop_04's Avatar
mcccop_04
i did exactly what it says on the bottle, and when i changed the oil about 50 miles after it was noticably darker. the last oil change i did the oil was nice and clean, and the car feels better.
Old Mar 12, 2007 | 05:25 PM
flash20's Avatar
flash20
alright well ima try that
Old Mar 12, 2007 | 06:04 PM
WhitePony02's Avatar
WhitePony02
I have heard of this, but what does it do?
Old Mar 12, 2007 | 06:27 PM
RyansQuick6
Reverse Gear Member
cleans everything in the engine and fuel system.
Ryan
Old Mar 12, 2007 | 09:06 PM
nappypalms's Avatar
nappypalms
You should record your seafoaming and upload it to YouTube like I did: http://www.youtube.com/watch?v=gHQu1zM-zqA
I used the Brake Booster vacuum line to do mine.
