Empty headed converters???
Old Nov 9, 2004 | 10:20 PM
twotabtess's Avatar
twotabtess
Default Empty headed converters???
Hi, bought a "95" with 3.8L & 5 Spd. A previous owner cut open all the cats, emptied them & welded them back close. Guess they did it for a couple HP's. The engine light is on all the time.... I guess from the O2 sensors not getting correct feedback. I ordered a mach hi-flow to replace the H. In the mean time could this be the culprit .... motor runs rough at low rpms & high gears? I got the GT take offs, also anybody need a GT front cat H setup?
Old Nov 10, 2004 | 12:40 AM
slegos888's Avatar
slegos888
Default RE: Empty headed converters???
turn off the bold type!!! that is the reason for the engine light! idk about the roughness tho i never heard anyone complain about that with no or gutted cats!!
Old Nov 10, 2004 | 02:34 PM
red2k1gt's Avatar
red2k1gt
you might wanna take a look down at your head gaskets...94-95's had a slight problem with them.
Old Nov 10, 2004 | 07:43 PM
twotabtess's Avatar
twotabtess
[&:] Sorry bout the bold..... I had a feeling the head gasket was the culprit. This is probably the "secret area" in front of the motor bleeding coolant! Costly job? Anybody have a nice 3.8 to swap?
Old Nov 12, 2004 | 01:34 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
if the head gaskets are leaking drop in a 351w.
Old Nov 12, 2004 | 03:11 PM
red2k1gt's Avatar
red2k1gt
yeah...because thats cheap...
Old Nov 12, 2004 | 07:36 PM
twotabtess's Avatar
twotabtess
Why.... would a "winsor" drop right in? mounts & all
Old Nov 13, 2004 | 01:03 PM
matthockey32
I ♥ Acer
with a new k-member and wiring harness. hello torque
Old Nov 18, 2004 | 05:00 PM
Finally a 5.0's Avatar
Finally a 5.0
ORIGINAL: matthockey32
right...have fun with that
Old Nov 18, 2004 | 07:58 PM
slegos888's Avatar
slegos888
and a new tranny, rear end modifications so everything worked right and still fit imo dont worth it! if you want a v8 buy a gt!
