The time is now
Well I had mine for a two years and still dont have many mods. Take your time , it would have been better to start on winter so you can have your car modded for those hot summer nights. Anyway good luck with that list.
ORIGINAL: forplay
You'd be better off getting the 8.8 rear end and beef it up. Hey I have almost the same list, but mineWILL be done in about 3 months, and I have only had the car 6 months. Sorry to rub it in, but having a good job helps out.
you guys care if I chime in?? You got a lot of mods listed there, and a lot of goalsman!!! I see one really big problem.. If you want to have the fastest V6 Personally I would not go with a supercharger. (they rob to much power) either spray or go with a single or twin turbo set up (single
But start with the basics. Get a tubular K-member. They make things a lot easier to work on.. and you loose like 60lbs. Upper and lower control arms. Tuner. and then take it from there.
Thats my advise I hope it helps
)But start with the basics. Get a tubular K-member. They make things a lot easier to work on.. and you loose like 60lbs. Upper and lower control arms. Tuner. and then take it from there.
Hey man thanks alot. Well i got the tuner! That's a start. So those chasis and suspension parts you listed, those make work on the car alot easier?? And to Whitecomet25about the hot summer nights, i live in Florida, it's always hot
. So thanks, so i should start with the suspension and then other mods. Where can i get a turbo for a v6??? i havent run across one yet.
mungodrums
Oct 7, 2015 04:01 AM
Sep 8, 2015 11:50 AM
