Its easy, black is ground. Red is the wire that goes to the parking lights or headlights. I ghetto rigged mine by having it go into the headlight port. Now when i have just the parking lights on, only the needles light up. When i turn on the actual headlights, then my unit lights up.
dont soldier just get some kind of wire nut or snap/crimp connect, and yes thats wat makes them light up
DO NOT USE WIRE NUTS IN A CAR!
Vibration and heat will back them off over time and you will end up shorting or worse starting a fireunder your dash. If youdon't want to solder the wires then crimp caps orinsulated bullet connectorsare the next best thing.
