turbo charged
reverse headers
Turbo
piping
BOV
Wastegate
Intercooler
Battery relocation kit
Bigger fuel pump
Bigger injectors
SCT and a dyno Tune
and a boost controller and a turbo timer will help
and im sure their is something im forgetting but thats just the basic you can do alot more
Turbo
piping
BOV
Wastegate
Intercooler
Bigger fuel pump
Bigger injectors
SCT and a dyno Tune
you don't need the battery relocation kit, there's more than enough room in front of the engine on the left to put the turbo.
and you also don't need the bigger injectors and focus fuel pump. you do if you intend to up the boost past 4.4 psi
you also need:
oil fittings
oil line
some kind of air filter for the turbo
you also need:
oil fittings
oil line
ORIGINAL: johnt2k7
yes u can buy the kit but if u have or can get any knowledge of how a turbo works and how they are setup and can weld you can make your own setup for about a $1000
