INTAKE MANIFOLD
Old Apr 12, 2007 | 01:57 PM
blade33201's Avatar
blade33201
Default INTAKE MANIFOLD
ANY ONE KNO WHERE I CAN BUY A PERFORMANCE INTAKE MANIFOLD FOR MY 2000 V6?
Old Apr 12, 2007 | 02:06 PM
jovez's Avatar
jovez
Default RE: INTAKE MANIFOLD
search button helps...
www.supersixmotorsports.com
www.rpm-mustangs.com
www.delkperformance.com
They are stock manifolds that are ported and polished.
Old Apr 12, 2007 | 02:10 PM
blade33201's Avatar
blade33201
THANK U VERY MUCH
Old Apr 12, 2007 | 04:03 PM
raz54's Avatar
raz54
WHY ARE YOU YELLING? Please, not all caps.
Old Apr 12, 2007 | 04:22 PM
v6stang07's Avatar
v6stang07
HUH WHAT DID U SAY???
no no caps and super six will prob take u the longest to get i think they are behind right now
Old Apr 12, 2007 | 04:36 PM
amrcnidyot's Avatar
amrcnidyot
im putting a windstar intake on mine. some people have said it should flow better than a ported upper. its a lot of work though, i just got done w/ the egr relocation bracket, ive done a tb adapter to make it sit lower, and i moved the iac to the side so it clears the hood. we will see how it works out hopefully tomorrow
Old Apr 12, 2007 | 04:46 PM
v6stang07's Avatar
v6stang07
hey is that intake windstar intake plastic and did u port it to match the gasket and lower perfect??
Old Apr 12, 2007 | 04:47 PM
cisurfer's Avatar
cisurfer
how do you move the iac becuase im going to have to with the blower
Old Apr 12, 2007 | 04:53 PM
amrcnidyot's Avatar
amrcnidyot
yea its plastic so it should stay colder too. and no i didnt do much porting, the gaskets are rubber oring type gaskets, they arent the normal kind. so i cant really gasket match em. i polished in inside but thats about it.
the thing that hangs off on lhe passenger side of the intake is the iac relocation bracket. i traced the iac and cut it out then drilled 2 holes for 2 brass fittings that i screwed into the metal. the hoses go from the brass fittings from the iac to...one goes after the tb and one goes before it..the one thats not plugged into anything goes to the cai. make sure you make it the right way though cuz if you do it backwards the iac will try to suck air outa the upper and into your cai.
Old Apr 12, 2007 | 05:15 PM
LilRoush's Avatar
LilRoush
SSM also has the SSX custom upper. Flows far better than a ported stock manifold.
