fuel pump
Old Apr 13, 2007 | 08:12 PM
v6stang07's Avatar
v6stang07
Default fuel pump
Which fuel pump does my 2000 take??
Old Apr 13, 2007 | 08:14 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: fuel pump
in terms of what?
Old Apr 13, 2007 | 08:24 PM
laserred02's Avatar
laserred02
i hope this link works, but it is $228 from advance auto parts
http://www.partsamerica.com/productd...52&PTSet=A
Old Apr 13, 2007 | 08:30 PM
v6stang07's Avatar
v6stang07
thanks, i think thats whats been causin my power loss, well here goes 250 bux, maybe this is it
Old Apr 13, 2007 | 08:32 PM
jovez's Avatar
jovez
I thought you said that the car was running perfect after the coil pack?
Old Apr 13, 2007 | 08:36 PM
v6stang07's Avatar
v6stang07
it was for about 2 weeks then it started again, i think my old coil pack is okay now, but it really was runnin perfect i couldnt get it to act up at all. It started to get really hot agian tho so i guess it just happened to cool off abou the same time i changed the coil
Old Apr 13, 2007 | 08:45 PM
jovez's Avatar
jovez
dam man, sorry to hear that. Is it just running hot? or missing/sputtering.. thermostat problem perhaps?
Old Apr 13, 2007 | 08:48 PM
v6stang07's Avatar
v6stang07
its not showin up hot at all, its just when the engine gets hot aka normal runnin temps it will loose power and sputter/misfire and eventually cut off, right before it cuts off my fuel pressure goes down to liek 15psi so i really think that is it now. I even took it to ford 2day, no one had ever heard of the problem but they hooked it up to their computer this time and the only problem was 2 injectors that were slightly slow on reaction, only out of specs by like 2-4 milli secs, not enough to cause ne thing
Old Apr 14, 2007 | 01:29 AM
v6stang07's Avatar
v6stang07
how hard would the install b u think, what just drop the tank, unscrew the pump extractor thing and replace it??
Old Apr 14, 2007 | 11:44 AM
tommy2273boy's Avatar
tommy2273boy
my SVT pump was $100 and took about 30-45mins to drop tank cover, unbolt 8mm screws that covers tank, then 6 5mm screws that hold the pump in, drop the SVT one, then rebolt everything
but if you need the whole basket, it might cost more.
