Fuel economy... or lack of
I got my 00 pony 3 months ago w/o error codes (kinda lucky), but when I'd look under the hood I assumed it never had maintenance so I did these before drive it:
Washed and degreased all engine, changed engine and tranny oils, used castrol syntec blend (cheap and worth for a semi-synt)with a k&n oil filter, msd spark wires and autolite double plat plugs (budget before all), went to a fast lube shop to clean the injectors and changed the fuel filter, took off upper intake manifold and cleaned (also the throttle body)and put a mac cai...
For some performance I changed the belt tensioner, idling pulley,a steeda underdrive pulley (replaced the belt for a smaller of course) and a h pipe exhaust...
the car runs pretty decent for less than 500 bucks, we just have a couple highways but when i jump the border sure i can step on the freeway, last sat i tried the ac and it works! (kinda dumb while ridin' a convertible but what the heck i was only testin')
Last week the fuel pump started to sound loud, i can hear it withrunnin engine and standed at the rear bumper, it's weird 'cuz i don't feel any fuel pressure problem (at least 1/2 tank always)but another 200surely about to be spent
well, i cleaned my mass airflow sensor, and whichever other one is right there in the intake hose as well, ias or ais, whichever, and i cleaned the throttle body best i could without taking it off, by just holding it open and cleaning it with a small ragwhere it was easily accessible. while that did actually give me a noticeable increase in performance when i test drove, i think i found the problem of the mileage. i tested the wheels' turning ability... and while the driver's side turns just fine, it takes a whole lot more force to turn the passenger's side front wheel. any idea what could be causing a binding brake? assuming that's what it is...
mrappe
Sep 26, 2015 10:16 AM
