delete grill installation problem
Old Apr 18, 2007 | 08:42 PM
hockeynick's Avatar
hockeynick
Default delete grill installation problem
I have a 2-pc delete grill. My problem comes early i the instalation. I removed the top 6 screw, but I cannot get to the bolts on the bottom. I think this is partly because I have a Cobra R body kit and it is attached by another type of screw. Should I remove the headlights and reach around to the bottom of the grill? Or do I need to remove the entire front body kit?
Old Apr 18, 2007 | 08:47 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: delete grill installation problem
it should be a small hex head screw holding it on, its really hard to get to but it can be done. if you can get a ratchet with a rotating end it would make things a ton easier. its what i used
Old Apr 18, 2007 | 08:54 PM
laserred38's Avatar
laserred38
whoever installed the front bumper may have used different hardware when they installed the grille. why did you use the stock grille with the Cobra R bumper in the first place?[&:]
Old Apr 18, 2007 | 09:08 PM
hockeynick's Avatar
hockeynick
Well it was a stock grill with the pony hammered out and a billet grill put on with tie straps.So I got the delete grill to fix that.
Old Apr 18, 2007 | 09:12 PM
hockeynick's Avatar
hockeynick
And no I didn't do it. The car had a previous owner.
Old Apr 18, 2007 | 09:16 PM
jovez's Avatar
jovez
Im actually in the same boat. They used different hardware and screwed down right in the middle of the grill location, hence the reason i still have that Fugly honeycomb grill.
Old Apr 18, 2007 | 09:30 PM
amrcnidyot's Avatar
amrcnidyot
looks like you might have to take off the front bumper. shouldnt be too hard. im sure you can do it in a short period of time
Old Apr 18, 2007 | 10:04 PM
raz54's Avatar
raz54
ORIGINAL: amrcnidyot
That's how I got mine out but it is a pain in the butt.
Old Apr 18, 2007 | 10:10 PM
laserred38's Avatar
laserred38
damn that sucks. but i'm glad you are fixing it. just take the bumper off!
Old Apr 18, 2007 | 10:24 PM
hockeynick's Avatar
hockeynick
Uhoh never done that b4. And its a body kit. I will see what I can do.
