Ford Symbol
here's what i've been thinking...i kind of want to take the decklid vinyl off of my trunk bc it doesn't look "clean".. i'm critical like that...
question though, if i remove the ford symbol on the back, do you think it will leave a dark mark around the circle where it lays?? i'm nervous
what should i use to take it off
ORIGINAL: raz54
Most factory emblems are die cast and held on with 2 (or more) push on clips over studs which go through to the inside.
ORIGINAL: raz54
Yeah i just removed mine to put on the actual honeycomb grill, wasn't expecting the holes. You can always cover them up with some other emblem of your choosing, unless you were set on going emblem-less
so if i take off my ford emblem, than there will be two holes going through the body of my car and into my trunk??
so basically i'm screwed..is that what you guys are trying to say?[&o]
Yes, you can use bondo, or the equivilant to fill the holes, then paint over them, but other than that, you're screwed. Just click on my sig and get yourself a nice 232 badge to cover up the holes.
