Check Engine Light
Old May 1, 2007 | 10:24 PM
imthehink's Avatar
imthehink
Default Check Engine Light
My check engine light came on and it was the egr pressure sensor. How long does it take for it to turn off? Thanks
Old May 1, 2007 | 10:26 PM
LilRoush's Avatar
LilRoush
Default RE: Check Engine Light
If it's bad, it will need to be replaced for the light to go off.
Old May 1, 2007 | 10:28 PM
imthehink's Avatar
imthehink
I did replace it.
Old May 1, 2007 | 10:41 PM
LilRoush's Avatar
LilRoush
Is it catching another code?
If not, unhook your battery, let it sit for 15min, come back and see.
Old May 2, 2007 | 12:02 AM
imthehink's Avatar
imthehink
I just checked it again. It's code P0401. I'll clean the egr valve and see. Generally, how long does it take for the light to go off after you've replaced the problem? Thanks
Old May 2, 2007 | 08:37 PM
LilRoush's Avatar
LilRoush
You have to reset the computer to get it to shut off. You can do that one of two ways....clear it with a programmer/code reader.....or unhook the battery for awhile.
Old May 2, 2007 | 10:24 PM
imthehink's Avatar
imthehink
Thanks
Old May 3, 2007 | 01:43 AM
LilRoush's Avatar
LilRoush
No problem.
djbigskrilla
Sep 20, 2022 01:04 AM
ChampInSD
Oct 2, 2015 04:55 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
