windstar intake
ORIGINAL: Whitecomet25
Well I think I can top that Here is a link
I have been studying this and I'm going to do this swap on my next paycheck. Cant wait...this is going to be sweet!
original:v6stang07
u got any pics of his set up??
v6stang wanted brackets for the one that fit under the stock hood.
Thats not the thread, its not even on this forum
Lemme show you some pics.
Nottice how he filled in the IAC, also the bracket on the side relocates the throttle cables so there is more clearance on the top of the intake. He is also running a 75mm 96-04GT throttle body. The plate he fabbed is his custom IAC relocation bracket.
He sanded down the plastic part next to the IAC and a little on the throttle body. Doing this along with the relocation of the IAC and throttle cables enables you to retain your stock hood.
ORIGINAL: NeoTokyo
BTW, you dont have to run that TB by the way, you have to remove material on the intake to allow this to work.
i used the stock metal bracket that was used for who knows what on the windstar and bent and cut it a little to fit the coil pack. it should work nicely and it doesnt look too bad. you wont really see it when everythings on.
and this, is what it will look like when im done w/ it. i cant f*ckin wait to get this all on the car and functional. it should look badass
Realistically, how much better is this thing?
Is it REALLY better than this intake?:
http://www.supersixmotorsports.com/p...eManifolds.pdf
