dash trim
Old May 7, 2007 | 10:44 AM
stangant's Avatar
stangant
Default dash trim
i would like to know how to remove the trim around the radio and the a/c controlls cuz i would like to move the a/c dials down to the bottom space and the radio up. is that possible and will i have to move more with it?
Old May 7, 2007 | 11:17 AM
Sparks232's Avatar
Sparks232
Default RE: dash trim
it just pulls straight off, i believe you have to take off the plastic section around the shifter first...... and then the top half just pulls straight off
Old May 7, 2007 | 11:22 AM
stangant's Avatar
stangant
its also in ah 2000 and i sa some screws but didnt know
Old May 7, 2007 | 11:23 AM
Sparks232's Avatar
Sparks232
hmm....dont know if they changed it from 00 to 02. but mine definatly came off with some tugging without taking any screws out, there are just some metal clips that hold it in
Old May 7, 2007 | 11:27 AM
stangant's Avatar
stangant
k thks ill try wen i get to my construction class cuz my teacher dont care if we work on ower cars.
Old May 7, 2007 | 11:40 AM
Insanestang's Avatar
Insanestang
Make sure you take out your airvents on the top of the middle trim and put your hands in the vent holes push down and pull out that will get the top half out easier then p ulling it and possibly breaking the clips holding it in.
Old May 7, 2007 | 11:43 AM
stangant's Avatar
stangant
how do you remove the air vents?
Old May 7, 2007 | 01:20 PM
kcocgibkcusuoy's Avatar
kcocgibkcusuoy
Well, in my '02 the vents are part of the trim. All I did was pull the bezel around the shifter off by sort of pinching the edges and pulling away from the radio trim, then all I had to do was carefully pull the radio trim straight out and it popped out. It was kinda nerve racking putting it back in though, it wouldn't sit just right, It still doesn't sit perfect at the bottom, but I guess I never noticed the fitments before.
Old May 8, 2007 | 10:54 AM
stangant's Avatar
stangant
ok in my car the are 3 screws 2 up front and 1 in the back. the air vents are part of the hole. it looks like i can move the a/c controls down 1 space
Old May 8, 2007 | 02:07 PM
tommy2273boy's Avatar
tommy2273boy
the vents arnt part of the trim, I took mine out and painted them.
they're just really in there.
the actual vent vents should push stright back and out of thier spots, the more flow(~~) and less flow([X]) has two things in the side of the vent that holds them in.
then when its all painted, snap everything back in.
