3.8 stroker kit and procharger.. need help
Old May 8, 2007 | 01:50 AM
AndySpeed's Avatar
AndySpeed
Default 3.8 stroker kit and procharger.. need help
aright my buddy has a 3.8 96 LX we wanna do a stroker kit on it.. how much will the 3.8 block hold.. also is there any good palce's we can buy a long block stroker motor aready built? also we are going to procharge it. We have close to 7500 to build with.. also how much will the stock 3.8 trannys hold.. what all upgrades do we need to put a stroker motor in a lx mustang
Old May 8, 2007 | 01:55 AM
v6kid07's Avatar
v6kid07
Default RE: 3.8 stroker kit and procharger.. need help
Go to www.supersixmotorsports.com
www.moranav6racing.com
www.rpm-mustangs.com
I would recommend doing the split-port swap personal opinion. If your gonna build up the car get rid of that 7.5" rear end or it will snap. Get the 8.8".
I would also recommend anything over 11psi upgrade the internals or they wont last long.
Old May 8, 2007 | 02:04 AM
AndySpeed's Avatar
AndySpeed
ok man thanks millions.. ya were deffently building the motor to with stand boost. but i just didnt know how much hp the stock block could handle.. didnt know if we need'd a aftermarket block or not.. kinda new to the v6 performance scene. but this looks like its gonna be a fun project. thanks bro
Old May 8, 2007 | 02:06 AM
AndySpeed's Avatar
AndySpeed
split port swap.. fill me in one this.
Old May 8, 2007 | 02:07 AM
SV6Mustang's Avatar
SV6Mustang
It's actually my Stang we are working on.. and I'm totally new to the hold building the motor... so any input will be a great help out.. I want my 6er to be one of kind in the area... so let me know what everyone thinks...
Old May 8, 2007 | 02:10 AM
AndySpeed's Avatar
AndySpeed
http://rpm-mustangs.com/cart/product...281&page=1 aright so this right here if we bolted up a blower to it. what do you think about it holding up and everything.
Old May 8, 2007 | 02:15 AM
AndySpeed's Avatar
AndySpeed
ahh i see split ports are the newer 3.8 blocks
Old May 8, 2007 | 02:23 AM
dhuskers_11's Avatar
dhuskers_11
actually 99-04 intakes not blocks
Old May 8, 2007 | 02:35 AM
NeoTokyo's Avatar
NeoTokyo
A 3.8L hasnt failed yet because it couldnt hold the power or RPM's, it has always been parts failing.
The 3.8L is actually more stable than the 5.0L because it doesnt have core shift problems.
There have been a couple 600hp sixers that had other parts fail but not the block itself.
The most memerable is Matt and Nathans SN95. They had an M112 SC pushing 22psi and a 100hp shot of Nitrous, they broke 600hp from what I remember and were shooting for 700hp. The head lifted off of the block which is what caused them to fall short of their goal.
Matt and Nathan have been working with SSM for a custom lower intake manifold for an eaton M112 SC to bolt right on.
A 4.2L crank is good for around 750hp-800hp. If you nitrate it then add another 200-300hp ontop of that. It may not be forged but its steel and they have not ever broken. Matched up with a set of 6.200" long rods and custom pistons you will be doing great. I highly suggest not boring your engine out to make a 4.3L if you are boosting it.
SSM has a great kit right now for $1795 with everything you need to complete a shortblock. Go through them for your kit. Have him nitrate it too, I think thats another 2-300 dollars, im not sure.
Old May 8, 2007 | 03:01 AM
Clif Brohn's Avatar
Clif Brohn
It happens to be true. 4.2l Stroker seems to be the best bet for F/I, if you want N/A Morana Racing makes 4.4L strokers for these engines. BUT, a split port intake swap should be the first thing done. The heads and intakes are just plain better all around than the single ports.
