Need a quick answer!
Old May 15, 2007 | 09:39 PM
Rook6's Avatar
Rook6
Default Need a quick answer!
If I could put a T-56 in now, it'd save me a ton of trouble when I swap the motor...that and the T-5 feels like it's on its last leg.
Somebody give me a reason that I can't put a T-56 in my car right now. Where would I get the bellhousing? Won't a bellhousing for a 302 work? The bolt patterns are supposed to be the same...
Old May 15, 2007 | 10:08 PM
NeoTokyo's Avatar
NeoTokyo
Default RE: Need a quick answer!
Ya but you need to figure out if the bolt pattern is the same on the trans as it is on the bell housing.
Do you have any other sources of somone doing this?
Old May 15, 2007 | 10:25 PM
Rook6's Avatar
Rook6
No, again I'm the trailblazer. They make bellhousings FOR 302s that fit T-56s. Shouldn't one of them work? Or, am I misunderstanding you?
Old May 15, 2007 | 10:34 PM
NeoTokyo's Avatar
NeoTokyo
I believe it does fit the V6
so there you go
Now you just need to worry about input shaft length
Also it needs to be a 10 spline.
So basicly your biggest problem is the input shaft length.
Old May 15, 2007 | 10:41 PM
Rook6's Avatar
Rook6
Care to elaborate? I'm a newb when it comes to trannies...and by that I mean transmissions, not transvestites...though my knowlege of them is just as lacking...thankfully.
EDIT: Wait, so why 10 spline? Why couldn't I do the 26spline conversion?
Old May 15, 2007 | 10:57 PM
NeoTokyo's Avatar
NeoTokyo
Im not all that strong on them either, just some basic knowledge.
If you change the clutch I would assume you could do it that way but you might have to have a custom flywheel made.
Its always easiest for me to figure new things if I am there and have my hands on them, Im great at that if I am there, but over the internet its hard LOL.
I'll do some searching.
Old May 15, 2007 | 11:00 PM
Rook6's Avatar
Rook6
Thanks, bro. Lemme know if you find anything out. I've also emailed Tremec to see what they say.
Old May 15, 2007 | 11:07 PM
NeoTokyo's Avatar
NeoTokyo
Btw we are talking about two different things, on the input shaft count the splines, there are 10
Old May 15, 2007 | 11:19 PM
NeoTokyo's Avatar
NeoTokyo
Ok so far I have found out that the input output shaft is actually smaller than the T5 and the T56 is a 10 spline on the input shaft.
Old May 15, 2007 | 11:20 PM
NeoTokyo's Avatar
NeoTokyo
You will probably need to contact Liberty Gear and have them make you a completly new input shaft with the 26 split output.
