Engine
Old Jun 9, 2007 | 08:09 PM
indisposible_teens's Avatar
indisposible_teens
Default Engine
I have a 1998 V6 Mustang 5M with 88k. I want to do a split port engine but I don't know whether I should buy a whole spilt-port engine or just do the split-port swap onto my engine. Which would be cheaper? I was thinking about getting a 99-00 V6 or GT but I don't want payments right now since my car is paid off and I am a poor college student anyway.What all would I need withthe engine swap or the intake swap?
Old Jun 9, 2007 | 09:04 PM
LilRoush's Avatar
LilRoush
Default RE: Engine
If you swap the whole motor, all you have to do is account for the newer style fuel rail which uses a returnless set up instead of the return style you have currently. It would be much easier than stripping your motor down and swapping parts.
Old Jun 9, 2007 | 09:44 PM
indisposible_teens
Default RE: Engine
That was what I figured but I didn't know for sure. Plus I wouldn't have as much down time.
Old Jun 10, 2007 | 01:47 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Engine
Well if you can find a 99-04 engine from a junk yard with decent milage for under $1K then do it, but you can get refinished split port parts for around $700 online at different site, and you also have the option of pulling the parts from a junk yard if you can't find any good 99-04 assembled engines. You also have the option to port and polish everything before the install when you just get the parts, this will add more hp and all around better performance, so this is something for you to consider.
Old Jun 10, 2007 | 11:35 AM
indisposible_teens
Default RE: Engine
I was planning on just getting the engine, building it up some and then dropping it in this winter.
Old Jun 10, 2007 | 11:32 PM
aj28's Avatar
aj28
Default RE: Engine
If you could just find an engine that would likely be the best and cheapest option, but if you're looking for a swap kit, check out SSM. Split-port upper and lower intakes plus all the accessories stuff you'll need to make it work with the older SN-95 fuel system... http://www.supersixmotorsports.com/p...GarageSale.pdf
Old Jun 11, 2007 | 02:51 AM
v6stang07's Avatar
v6stang07
Default RE: Engine
check ebay for an engine, i have seen many low mileage split ports for 500 bux
Nick Oliver
Oct 17, 2018 04:22 AM
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
