Catless
Old Jun 11, 2007 | 03:56 PM
v6stang07's Avatar
v6stang07
Default Catless
Im havin a custom o/r h pipe made with no bungs, will i just need mil eliminators to turn my cel off?
Old Jun 11, 2007 | 04:34 PM
raz54's Avatar
raz54
Default RE: Catless
Yeah just for the front two 02's though
Old Jun 11, 2007 | 04:38 PM
v6stang07's Avatar
v6stang07
Default RE: Catless
so 2 MILs or a set of MILs is all i need
lemme get this straight, these plug in from the O2 wire to the O2 sensor on the front 2 sensors right
Old Jun 11, 2007 | 05:31 PM
forplay's Avatar
forplay
Default RE: Catless
you'll need them for the back ones too or a tuner to turn them off
Old Jun 11, 2007 | 05:42 PM
v6stang07's Avatar
v6stang07
Default RE: Catless
well will i need 2 or 4 of them then???
Old Jun 11, 2007 | 07:14 PM
v6stang07's Avatar
v6stang07
Default RE: Catless
bump!
Old Jun 11, 2007 | 07:34 PM
flash20's Avatar
flash20
Default RE: Catless
4! even if u turn them off, ur car will run rich
Old Jun 11, 2007 | 08:21 PM
v6stang07's Avatar
v6stang07
Default RE: Catless
what if i leave the front 2 in and just get 2 mils?
Old Jun 11, 2007 | 08:29 PM
flash20's Avatar
flash20
Default RE: Catless
ORIGINAL: v6stang07
i think thats what juan has
Old Jun 11, 2007 | 09:14 PM
cominus's Avatar
cominus
Default RE: Catless
You guys are so weird.
You only need 2 mils. The front 2 are connected to your exhasut manifold/headers. If you have the exhasut manifold dont Fuc|< with them. If you have LT headers all you need is extensions. For the rear 2 you most likely wont need extensions cuz they're so close to the tail pipes, but you will need the mils. A little splicing will do the trick, unless you have a tuner, then you probably wont even need to plug in the rear 02 sensors, but if you are using mils do make/install bungs unless you just wrap them together or something, which will be kinda ghetto but hey, whatever works.
So like this
Header/Manifold--front 02 snifer-----rear 02 mil/tuned off-----------catback
