balancing and alignment problem??! HELP!!!
Old Jun 11, 2007 | 11:32 PM
FBCBEER's Avatar
FBCBEER
Default balancing and alignment problem??! HELP!!!
I got my new rims and tires on and fully balanced and now the steering wheel shakes a little right at 50mph. Not lower or higher mph. Just around 50mph. I even took them back to get rebalanced and it does the same thing. I drove going 70-85 and it doesnt shake at all. Also, when I brake hard or slow, the wheel shakes and pulls to the right. I know that is a brake issue and I just need to turn the rotors, but whats up with my wheels/tires?
Old Jun 12, 2007 | 12:12 AM
v6stang07's Avatar
v6stang07
Default RE: balancing and alignment problem??! HELP!!!
that could also have somthing to do with a warped rotor
u may also want to get ur tires trued up, if they are balanced thats all i can think of
Old Jun 12, 2007 | 01:23 AM
FBCBEER's Avatar
FBCBEER
what exactly does truing do? I dont think its a rotor issue because when I had my stockers on, it was as smooth as glass through 50, now with the new rims and tires, its shaky right around 50 and thats it. WTF is wrong?
Old Jun 12, 2007 | 12:25 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: FBCBEER
Make sure the crush washers on your rotors (take the rims off) were taken off. If you still had stock rims I'm guessing the little washers that hold the rotors on while it goes down the assembly line are still on your car. You don't need them. A lot of after market rims sit flush on the rotor and those washer are thick enough to cause some vibration at certain speeds.
Old Jun 12, 2007 | 03:10 PM
v6stang07's Avatar
v6stang07
truing up tires sounds bad but is a good idea, they take the rim and tire off and spin it on like a lathe, then they shave a little off the surface of the tire in order to make the contact patch perfectly square and level
Old Jun 12, 2007 | 07:37 PM
FBCBEER's Avatar
FBCBEER
Yeah, my wheels do fit really snuggly onto my lugs. How would I be able to tell if they took off those rings? I am putting my stockers on in the winter, so would they have given me the washers?
Old Jun 12, 2007 | 07:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: FBCBEER
You dont need the washers is the point. The only way to tell if they actually took them off is to remove a couple of rims (front preferably) and see if there are washers on them. If they did remove them they would've just thrown them away. I doubt it's a rotor issue or the problem would present when pressing the brake pedal as well.
Old Jun 12, 2007 | 08:45 PM
johnt2k7's Avatar
johnt2k7
the pull to the right when breaking is common what kind roads u drive on most road are curved some more than others especialy country roads they are curved so that water runs off the road so it doesnt puddle
u can find out if it is that by simply driving on the wrong side of the road while no one else is coming and brake if its that it should pull the other way
Old Jun 12, 2007 | 09:50 PM
v6stang07's Avatar
v6stang07
very true about the roads
they are made to shed water away from the center of the road
Old Jun 12, 2007 | 11:58 PM
johnt2k7's Avatar
johnt2k7
some arround here are realy bad u kinda have to drive with the wheel a lil off center to go straight and as soon as u hit the brake it takes off like a rocket to the sholder it actualy catches u off guard when it hapens some time because u may be on the phone or only one hand on the wheel but its only in certain intersections and stop signs
