Bad Gas?
Old Jun 14, 2007 | 01:23 AM
iceache's Avatar
iceache
Default Bad Gas?
Ok, so is it possible that Regular gas is not good enough for the mustang? I started hearing a noise.. and now that ive switched it to supreme, no noise..
Old Jun 14, 2007 | 01:26 AM
ProvingGrounds's Avatar
ProvingGrounds
Default RE: Bad Gas?
Could just be bad gas from a certain station. Or that you had some water in the system. What kind of noises?
Old Jun 14, 2007 | 01:28 AM
iceache's Avatar
iceache
the only way i can explain it is this... it sounds like a diesel engine on idle... and it only happened when i tapped the gas or floored it.. it only happened when i was driving
Old Jun 14, 2007 | 01:35 AM
ProvingGrounds
any tuning done to your car?
Old Jun 14, 2007 | 02:32 AM
00raging stang's Avatar
00raging stang
thats weird ive never heard any problems like that before
Old Jun 14, 2007 | 03:08 AM
l_shizzle_l's Avatar
l_shizzle_l
Sounds like bad gas from the station. There is this gas station down the road from my house, but i don't use it because the gas sits there a lot because no one goes there. And it does make a difference when i run it in my car.
As for getting supreme gasoline, it is a waste of money and could be doing worse to your car if anything at all. These cars were designed to run on regular gasoline, not supreme. So using a different grade of gasoline could be more bad than good for your car.
Old Jun 14, 2007 | 04:15 AM
MustangMike2001's Avatar
MustangMike2001
I read in the manual somewhere that you're supposed to use regular unleaded and that some knocking is normal.
Old Jun 16, 2007 | 06:19 PM
iceache's Avatar
iceache
wierd, i think im gonna switch it back to regular once i get down to empty
Old Jun 16, 2007 | 06:50 PM
LilRoush's Avatar
LilRoush
Yes, it was most likely a poor station. there is no point in running higher octange fuel in your car unless you are tuned for it.
Old Jun 16, 2007 | 08:16 PM
mustang_matt's Avatar
mustang_matt
higher octane does wear out engine parts quicker since it burns hotter than our engines were designed for.
