NITROUS
Old Jun 15, 2007 | 05:13 AM
blkfireracer24's Avatar
blkfireracer24
Default NITROUS
For my mustang I'm gonna buy a 75 wet shot nitrous system. Any good places I can buy them and what else should I consider when buying Nirtous (like what else should I get other than the bottle and the lines and injectors?) How many shots can I get out of a 15lbs bottle and out of a 10lbs bottle.
Old Jun 15, 2007 | 10:45 AM
darthstanger's Avatar
darthstanger
Default RE: NITROUS
I would go dry...
Old Jun 15, 2007 | 01:41 PM
laserred02's Avatar
laserred02
Default RE: NITROUS
you should start reading this before you consider nitrous. nitrous can be fun and safe for your engine but you have to know what you are doing and run the proper spark plugs, and the proper tune.
https://mustangforums.com/m_639288/tm.htm
Old Jun 15, 2007 | 06:57 PM
raz54's Avatar
raz54
Default RE: NITROUS
ORIGINAL: darthstanger
I would go dry...
+ 1 on that. A dry system is safer to use. I would get an rpm window switch and a bottle warmer to keep the pressure around 900 psi for the best (and most consistant) results.
Old Jun 15, 2007 | 07:10 PM
l_shizzle_l's Avatar
l_shizzle_l
Default RE: NITROUS
i would also highly advise getting a tune if you are planing on using it a lot.
Old Jun 15, 2007 | 07:19 PM
02MustangV6DD's Avatar
02MustangV6DD
Default RE: NITROUS
Safest would be a fogger system for sure. I plan on putting 3 injectors instead of 6. With a reagular shot its one big shot instead of a whole bunch(fogger). NO TUNE, NO NITROUS
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
