Spark Plug Question
Old Jun 17, 2007 | 10:58 PM
telstar8's Avatar
telstar8
Default Spark Plug Question
Can someone help me out with a question regarding my spark plugs for a 2001 V6, 3.8L Stang.
I just recently changed my spark plugs on my 2001 mustang. I took out the stock ones from 01 and replaced them with OEM plugs and made sure the gap was right. I didn'tchangethe spark plug wires though. After installing the parts I took that car out for a road test and noticed a slight hesitation in the vechicle when I accelerated. I noticedit morewhen I had my A/C on though. Has anyone had this problem or known someone who has? If so how do I fix it? The car was running fine prior to the spark plug change. Could it be now the wires now need changing?
Old Jun 17, 2007 | 11:08 PM
v6stang07's Avatar
v6stang07
Default RE: Spark Plug Question
nevr had that problem, it would be wise to replace some 6 yr old wires, i would go ahead and replace them as just routine maintenence if nothing else
Old Jun 17, 2007 | 11:25 PM
raz54's Avatar
raz54
Replace the wires. Pulling on them to get them off may have broke some of the wires so they are not letting the full amount of current pass through (more resistance).
Old Jun 18, 2007 | 01:22 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: raz54
+1
replacing the plugs without replacing the wires is kind of defeating the purpose.
Old Jun 18, 2007 | 01:26 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: raz54
+3
Changing the wires is nearly a MUST when changing plugs.
Old Jun 18, 2007 | 06:31 PM
notasinger's Avatar
notasinger
Changing the plug wires is worth the expense to be sure that your vehicle is running at peak performance.
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Emblazoned
Sep 3, 2015 10:45 PM
cbird1177711
Sep 2, 2015 04:12 PM
