Check Engine Light...NEED HELP
Jun 18, 2007 | 06:25 PM
okay Iwoke up today at 7am and my check engine light was on........read the code it was p0402......it said excessive EGR Flow.....how do i fix it?????
Jun 18, 2007 | 06:28 PM
RE: Check Engine Light...NEED HELP
Your DPFE valve/sensor/switch needs to be replaced. P0402 and P0401 (the opposite of what you got) both require replacement of that valve.
It looks like this
and is located on the passenger side to the left of the EGR valve.
Jun 18, 2007 | 06:40 PM
is it expensive and hard to replace?
Jun 18, 2007 | 06:50 PM
Quote:
ORIGINAL: blknismo180
Cost =? My wifes Escape had the same problem, it was done for free under warranty. It can't be more than $30-$40
It's easy to replace, 1-2 bolts, two vacuum lines, and one electrical pigtail. 10 minutes tops
Jun 18, 2007 | 06:58 PM
Try cleaning it to start. But you should replace it at some point.
Jun 23, 2007 | 01:01 AM
yeah replaced it.......$78
but it had to be done.....
Jun 23, 2007 | 03:21 AM
$78 for the part?
Jun 23, 2007 | 03:03 PM
yeah i replaced mine too because my car was stumbling after i cleaned my IAC out really well and it cost $78 also...ford dealerships got me on that one [&:]
Jun 27, 2007 | 03:37 PM
it was $158 at ford...lol...i bought mine from an auoparts store.....and then i found out i broke anoher cam shaft synchroniser
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
