iHELP!!!
Old Jun 19, 2007 | 02:12 AM
kcjh23's Avatar
kcjh23
Default iHELP!!!
ok so I was changing my differential fluid.. by the time i got to filling it with about the third quart of fluid it started flowing out the fill up hole, but it didn't feel like it was anywhere near being filled.. any ideas why its doing this?
Old Jun 19, 2007 | 02:22 AM
kcjh23's Avatar
kcjh23
Default RE: iHELP!!!
is it maybe just filled and its hard to tell?
Old Jun 19, 2007 | 02:28 AM
raz54's Avatar
raz54
It doesn't hold a whole lot (less than 2 qts). Let it stop running out then put the plug back in.
Old Jun 19, 2007 | 02:33 AM
kcjh23's Avatar
kcjh23
well i was under the impression it was closer to 2.5-3 quarts for some reason.. and then the idiot at pepboys told me 4 which i knew was too much.. well it wasn't a whole lot that was coming out the top so its probly alright
Old Jun 19, 2007 | 02:48 AM
ProvingGrounds's Avatar
ProvingGrounds
About 1.80 quarts exactly.
Old Jun 19, 2007 | 02:54 AM
kcjh23's Avatar
kcjh23
yeah now i know.. i went ahead and drained out the little excess that i had in there.. anybody have any idea how much a manual tranny holds?
Old Jun 19, 2007 | 03:01 AM
ProvingGrounds
Wait, how did you "drain" the excess? Also make sure that you use friction modifier or "additive". you can pick up a bolttle from the dealer or get a TransX tube from Advance Auto.
2.6 liters for the tansmission - Mercon
Old Jun 19, 2007 | 03:04 AM
kcjh23's Avatar
kcjh23
i just unsrewed the fill plug and let the excess drain out through it.. wasn't much extra tho.. which means i need to do that to the trans to cus i put a little too much in.. now i know tho.. cus the pepboys guy told me way too much.. so all together with the trans and diff. i bought about three quarts too much fluid... wasted $30
Old Jun 19, 2007 | 03:07 AM
kcjh23's Avatar
kcjh23
you meant 2.6 quarts right?
Old Jun 19, 2007 | 03:21 AM
ProvingGrounds
LOL, I bought three quarts of Valvoline 75W140 for $2 a pop because they were on clearance at advance auto parts.
Anyways, stick a towel (lint free) through the fill plug to extract some more fluid. You need to be about 1/4" or so under the fill plug level.
And no, I am pretty sure that I meant liters. That equals 2.75 quarts.
Good luck!
