Power window question
Old Jun 20, 2007 | 09:45 PM
misshinkle's Avatar
misshinkle
Default Power window question
The driver window won't go up. I replaced the 20A fuse. I switched the passenger button with it and it still won't go up. It's getting power because I can hear the fuse tick when I press it. Any suggestions? Thanks
Old Jun 20, 2007 | 10:10 PM
02MustangV6DD's Avatar
02MustangV6DD
Default RE: Power window question
You hear the fuse tick? test it with a test light. Its prolly your motor
Old Jun 20, 2007 | 10:14 PM
98ponycar's Avatar
98ponycar
Slam the door a couple times and bang on the door panel with your hand,then try hitting the button. It may make it go up. If it does, don't roll it down again until you get it to the shop to have a new motor installed.
Old Jun 21, 2007 | 12:24 AM
misshinkle's Avatar
misshinkle
I took the panel off and hit the motor as I pressed the button. The window came right up. thanks
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
