8.8" rear
Old Jun 25, 2007 | 08:31 PM
forplay's Avatar
forplay
Default 8.8" rear
Will a 8.8" rear end bolt right up to a 99-04 V6? If not what modifications will be needed? I want to put 3.55's in my car, I hate my 3.73's on the highway. 2700 rmps at 80 mph, thats working my motor way to hard!!
Old Jun 25, 2007 | 08:38 PM
amrcnidyot's Avatar
amrcnidyot
Default RE: 8.8" rear
yea, if you get an 8.8 from a 99-04 stang it should bolt right up.
Old Jun 25, 2007 | 08:54 PM
forplay's Avatar
forplay
And can I use the same drive-shaft or will I need a longer/shorter one?
Old Jun 25, 2007 | 09:38 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Everything is the same. Nothing to modify other than programming.
Ryan
Old Jun 26, 2007 | 10:45 AM
darthstanger's Avatar
darthstanger
can you change your rmp with your tuner?
Old Jun 26, 2007 | 03:21 PM
amrcnidyot's Avatar
amrcnidyot
ORIGINAL: darthstanger
yea, you can adjust for differnt gear sizes and different tire sizes. but if you get a 99-04 gt rear you shouldnt have to adjust anything. im pretty damn sure tehy ahve 3.23 gears also. if you get a mach rear they will have 3.55 i think. so then you would have to adjust it.
Old Jun 26, 2007 | 03:59 PM
forplay's Avatar
forplay
3.55 is what I want. Anyone know where I can find one at?
Old Jun 26, 2007 | 04:04 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: forplay
here's a write up if you still want to do the swap...
http://www.miracerros.com/mustang/axle.htm
Old Jun 26, 2007 | 04:22 PM
94Blk5.0's Avatar
94Blk5.0
Quick fix for high rpm's is to slow down. I run about 2000 rpms at 65 with 3.55's but my fifth gear ratio is .67 or.68 as opssosed to your ratio or .73 or .75. Going from 3.73 to3.55 will lower your rpm's about 200 Iam guessing. You should be able to find a 3.45 ratiofor your 7.5 rearend from Richmond Gears.
Old Jun 26, 2007 | 08:19 PM
RyansQuick6
Reverse Gear Member
I have a complete 3.55 rear end in my garage. I want 3.73's.
Ryan
