service engine soon code
Old Jun 26, 2007 | 09:51 PM
forplay's Avatar
forplay
Default service engine soon code
My service engine soon light just came on, I have a X-CAL 2, so I plugged it in and read the code. It says P1507 IDLE AIR CTRL UNDSPD ER can someone please tell me what it says. I have a feeling it has something to do with my mass air being I just cleaned it.
Old Jun 26, 2007 | 10:03 PM
laserred02's Avatar
laserred02
Default RE: service engine soon code
that indicates and idle air control problem, your iac valve is hooked up to your throttle body make sure all connections are tight. same thing with the maf, make sure that you plugged everything back in correctly. is the idle speed lower than what it normally is? you can try pulling off the iac and cleaning the valve with brake parts cleaner, letting it dry and plugging it back in.
good luck.
Old Jun 27, 2007 | 03:10 AM
amrcnidyot's Avatar
amrcnidyot
under speed would make me thing that either its unpluged or you need a new one. id do like laserred said and pull it off and try cleaning it first. then clear the code and see if it comes back. its screwed on w/2 bolts. its mounted right behind the tb on the back side of the upper.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
mdj89
Sep 6, 2015 11:08 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 1, 2015 08:16 PM
