NOT STARTING.
Old Jul 7, 2007 | 02:38 PM
561boii's Avatar
561boii
Default NOT STARTING.
yes, my engine is not starting, when i turn the key i hear a big CLICK but nothing will happen...i checked the starter and that works....my battery works, i eventried jumping my car just to make sure, and that still didnt work...dose anyone have any other ideas as to why this is happening????? =/
Old Jul 7, 2007 | 03:16 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: NOT STARTING.
Check your battery cables. If you have corrosion and deterioration, then your starter isn't getting all the juice it needs.
How did you check the starter and battery?
Old Jul 7, 2007 | 04:03 PM
flash20's Avatar
flash20
fuel pump
Old Jul 7, 2007 | 04:39 PM
561boii's Avatar
561boii
well, i checked the battery terminals and they had some corosion on them, i wire brushed all of it off and cleaned the surfaces and tried again and nothing. just the same click. i know the battery is working because i took the starter off and cranked it and that worked. so i know its neither of them. although i think it has something to do with the battery because i turned on the lights, cranked it and they dimmed quite a bit....but how would it be the fuel pump???? wouldnt it atleast turn over....?
Old Jul 7, 2007 | 06:11 PM
l_shizzle_l's Avatar
l_shizzle_l
Make sure you are pushing the clutch in???
Sounds like a starter issue to me.
Old Jul 7, 2007 | 06:47 PM
03YellowPony's Avatar
03YellowPony
2 words.....STARTER SOLENOID
Old Jul 7, 2007 | 07:09 PM
561boii's Avatar
561boii
im sorry, but i dont understand how it would be anything to do with the starter if it works...???[&:]
and whats a starter solenoid?
Old Jul 7, 2007 | 07:27 PM
simpsonfan13's Avatar
simpsonfan13
ELEKTRO-FIDE Moderator
From: In Geo-synchronous orbit over redass' bathroom,
ORIGINAL: 561boii
could be the fuel pump. most stangs (at least new edges) have an emergency pump
shut off button in the trunk maybe you pressed it by accident?
that noise actually came from my dads astro van when its
pump facked up
Old Jul 7, 2007 | 10:31 PM
561boii's Avatar
561boii
ORIGINAL: simpsonfan13
ORIGINAL: 561boii
pump facked up
well then if that be the case, which i hope it is, how do i fix that problem?
Old Jul 7, 2007 | 11:31 PM
Daytripper540's Avatar
Daytripper540
There is a little compartment in the front(Closest to you if you're standing behind the car) left part of the trunk. You unscrew the screw on it and pull off the lining. Then press the red "easy" button.
