k&n cold air intake
Old Jul 9, 2007 | 08:53 PM
02stangridin's Avatar
02stangridin
Default k&n cold air intake
I have an 02 mustang V6 with dual exhausts, should i add a k&n cold air intake? would it sound or run any better? the duals have a good sound...im just wondering whether or not its a good idea to add the intake? thanks.
Old Jul 9, 2007 | 09:17 PM
Xemeth's Avatar
Xemeth
Default RE: k&n cold air intake
It's a waste of money. You'll get like 2 hp max.
Old Jul 9, 2007 | 09:26 PM
94Blk5.0's Avatar
94Blk5.0
Cold Air Intakes are generally worth it, just rember they are a bolt-on. Huge gains should not be expected, all depends on the condticion of the factory intake , the design of the new intake, and the engine's need for air. K&N intakes on a 3.8 are worth close to 7 HP , which seems very realistic.
http://www.knfilters.com/search/appsearch.aspx
The cai shold compliment the duals well, and the unresticted intake noise will make you grin for a few days.
Old Jul 9, 2007 | 10:14 PM
raz54's Avatar
raz54
If you go with a K & N intake make sure you keep the maf screen in place or it won't run right.
Old Jul 9, 2007 | 10:16 PM
lovemy6's Avatar
lovemy6
i have an 02 with dauls and a K&N cai....the exhaust sound wont change....the only sound you will hear is the intake sucking air but imo it sounds good....you wont feel any more power but you will feel better throutle responses and some even say you will gain gas milage...but be careful many people have had problems with the intake such as me.....in the instructions for the cai kit it says nothing about reusing the mass air flow screen but chances are you will need to
Old Jul 9, 2007 | 10:18 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: 94Blk5.0
you will net 2 HP, just throw a K$N in the stock box, if it made that much of a difference why wouldnt one come stock?
Old Jul 9, 2007 | 10:25 PM
94Blk5.0's Avatar
94Blk5.0
The K&N link provides a dyno for a 3.8 with a FIPK. You could remove the silencer and add a drop-in K&N and pick up a few HP, but more power can be found with the whole system. They are not stock becasue of NHV Federal standards and the maintience associted with a reusble filter like the K&N. Keep in mind a sixxer's air demand if not as great as a larger displacement V8, so gains will be modest, as expected.
Old Jul 9, 2007 | 10:32 PM
94Blk5.0's Avatar
94Blk5.0
My bad: Heres the correct link-
http://www.knfilters.com/search/prod...x?Prod=57-2532
Dyno Results on the FIPK
http://www.kandn.com/dynocharts/57-2532.pdf
And remember airflow mods work together for a bigger net gain thean the individual compontens added together. With duals in place, better gains can be expected than on a stock car by a few HP.
Old Jul 10, 2007 | 05:52 AM
94Blk5.0's Avatar
94Blk5.0
I have probaly posted one too many link in this threas but heres another:
http://store.summitracing.com/partde...p;autoview=sku
The BBK CAI for about $180 and gaines simliar to the K&N can be expected.
Old Jul 10, 2007 | 09:35 AM
mustangman02232
ORIGINAL: 94Blk5.0
thats because thats K&Ns dyno, you will not net nearlythat much,
