split port swap..?
Old Jul 16, 2007 | 05:26 PM
kraz3y's Avatar
kraz3y
Default split port swap..?
what else is needed? for my 98 other than the uupper?? and also would it jus be easier to swap a whole engine into my car...what else mods would be needed for that?
Old Jul 16, 2007 | 05:35 PM
stanginlikeamug's Avatar
stanginlikeamug
Default RE: split port swap..?
if your gonna swap a whole engine you might as well drop a v8 in it.
Old Jul 16, 2007 | 06:06 PM
amrcnidyot's Avatar
amrcnidyot
you need quite a bit. the best way to do it would probably be to buy the kit ssm sells. its only 800.
CLICK ME
Old Jul 16, 2007 | 07:54 PM
jthorn9's Avatar
jthorn9
The Godfather
Throttle body, upper intake, lower intake, heads, push rods (old ones may work, but new ones aren't a bad idea), new head bolts (old bolts should not be reused), full wiring harness, 99-04 spark plugs, 99-04 coil pack relocation, slight modification to the fuel system (can't remember what exactly though), 19lb hr fuel injectors (larger would be reccomended if you're going with a ported system or plan on an S/C in the future, you may also need to modify your MAF if you go over 24lb), upper/lower intake gasket, throttle body gasket, head gaskets, valve cover gaskets, all for a 99-04.
That's about all I can think of, a 99-04 ECU wouldn't hurt either.
Old Jul 16, 2007 | 09:01 PM
Junior OTard's Avatar
Junior OTard
Banned
now i know what my next major mod will be!
Old Jul 17, 2007 | 05:23 AM
kraz3y's Avatar
kraz3y
hmm so im prolly better off getting the whole damn engine...its 250 for a 01 v6 with 50,000 miles...not bad...i dont wanan swap a v8...else i woulda got one in the first place haha i want v6 braggin rights!
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
TfcCDR
Sep 14, 2015 12:08 PM
