headllight installation help
Old Jul 18, 2007 | 04:26 PM
lhsdgs71358's Avatar
lhsdgs71358
Default headllight installation help
i just got my headlights and taillights today and i already gotten the taillights installed but i am having problems on how to get the headlights installed, is there an site for me to use on how to get it installed or something like that? thanks.
Old Jul 18, 2007 | 04:28 PM
Flake6899's Avatar
Flake6899
Default RE: headllight installation help
Pop your hood....theres two brackets behind each headlight. Take them out. Then disconnect the bulbs by kinda twisting them around. And to install the headlights its the reverse....if you have any more problems let me know
Old Jul 18, 2007 | 04:33 PM
moontang's Avatar
moontang
ORIGINAL: Flake6899
haha flake your suchasarcastic hero but yea thats it
lhsdgs71358
ORIGINAL: Flake6899
theres one prob... i tried to get to the brackets but my sockets are too long and tried to use the wrenches it would take about like 2 hours to get one headlight installed, idk...i just got back from my friends house and he doesnt have the right set of tools to get it installed and everything
Old Jul 18, 2007 | 04:43 PM
Flake6899's Avatar
Flake6899
sockets? just use your hands....they pull right up.
Old Jul 18, 2007 | 04:48 PM
Flake6899's Avatar
Flake6899
Wait do you have a 94-98 mustang or 99+? Sorry I was talking about 99-04
Old Jul 18, 2007 | 05:15 PM
SilvrStang's Avatar
SilvrStang
If u have a 99-04 stang there are black metal clips, two on each headlight , they look sorta like THIS
O
Old Jul 18, 2007 | 05:17 PM
SilvrStang's Avatar
SilvrStang
For 94-98 i found a writeup on moddedmustang forums .Read below.
Open up your hood, on top of each of the headlights there are these black plastic covers that are held down by some kind of pins (I dont know what they're called), you can just pull them right out with a hammer (like that side of it you would use to pull out a nail).
This opens up the back of your headlights. there is a single bold holding the corner light, with a nut holding it in place. use a ratchet or wrench to remove the nut. This will allow you to simply pull the corner light out. Pull it out to the side of the car, not in front of it...it might in there pretty good but just keep pulling, it WILL come out, even if you're scared you're gona break something.
Now with the corner light out of the way, this leaves more room for pulling out the headlights (im pretty sure it wont work unless you takeout the corner light first).
k this parts really hard to explain...there are screws on the headlights that go into holes in the frame, but they're not held on with a nut, they're held on with this black plastic clip sort of thing. these are just behind the headlights. you need to squeeze the sides of the clip to make it smaller so that it will slip out through. it can be a really bitch...just feel around on them and you should be able to figure out what i mean.
hope this helps...just remember when you put them back in, be very careful to not push them in too hard because then those black clips will break and itll be loose forever, which sucks. this happened to me but i was lucky in the sense that i was replacing them and so i had the old clips to replace them with. I really dont know if "clip" is the proper term for this, im just throwing words around...
Old Jul 18, 2007 | 05:20 PM
lhsdgs71358
ORIGINAL: SilvrStang
ok, ill give it a try, thanks for your help!
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
