2000 With a slight problem
Old Jul 20, 2007 | 06:37 PM
SuPa StaLLiOn 7's Avatar
SuPa StaLLiOn 7
Default 2000 With a slight problem
I have a 2000 convertible with 110k on it... whenever I go full throttle with my Mustang, the battery light illuminates for a bit until the car switches into its next gear... it's an automatic... can anyone help me with my problem? Thanks a lot.
Old Jul 20, 2007 | 06:39 PM
SuPa StaLLiOn 7
Default RE: 2000 With a slight problem
Old Jul 23, 2007 | 04:07 PM
Derf00's Avatar
Derf00
Gentleman's Relish
It's a bad alternator...or one that's going bad. My 00 V6 manual tranny did that too. I've got 116K on mine. It started around 90 K (replaced it at 100K). Took the alternator to Autozone and had them bench test it. It failedthree out of five tests. I had them run it 5 times because the first time passed. Second time failed, third passed, 4th and 5th failed.
Replaced the alternator, no more flickering battery light at high RPM or WOT and no more dimming lights when the A/C kicks on.
Old Jul 23, 2007 | 05:00 PM
SuPa StaLLiOn 7
Hey thanks man, I'll go get mine tested as well. I'm not sure about the dim lights with the A/C on because at night I usually roll with the top down, but when I try givin some extra gas with the A/C on, the engine response is bad and the A/C gets warm. Can this be caused by this also?
Old Jul 24, 2007 | 03:36 PM
Derf00's Avatar
Derf00
Gentleman's Relish
If you're flooring it with the A/C on, no, it's not related to the alternator. Our A/C compressors have a high RPM/WOT cuttoff switch that keeps the compressor from getting damaged. So, whenever you're above 4-4.5K steady or you floor it, it disengages the A/C clutch which turns off the compressor. Thus you get warm air for a few seconds until you either let of the gas or you drop the RPM by either upshifting or slowing down.
Old Jul 24, 2007 | 03:48 PM
SuPa StaLLiOn 7
Hey thanks a lot man, yeah i noticed when I stop giving it gas it turns cold again. I'm bringing it to my guy tomorrow, and I think it's under warranty from the guy I bought it from, so I should be good.
Carolina Man
Carolina Regional Chapter
35
Aug 7, 2017 10:52 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Jose Corretjer
Sep 8, 2015 06:32 AM
