EASY MIL QUESTION
I bought a o/r xpipe for a 2000 v6 mustang i noticed on the old set up there is four plugs here is my question do i need four mil eliminators? or is there a spot on the new x pipe where some of these sensors screw in thanks to all who respond!!
No, they sell them in pairs, which is all you need.
Bottom right: http://www.v6mustangstuff.com/engine.htm
The front two go into the two bungs nearest the manifolds just like on your stock midpipe. They monitor the exhaust before the catalytic converters on a stock setup, so nothing has changed with respect to what they are monitoring when you use them on an offroad midpipe. The two that used to be behind your cats are the ones that are now monitoring exhaust that used to go through your stock cats (which are no longer there), so they are the two that must be "fooled" into thinking that the cats are still working properly.
ORIGINAL: ARdoller
if someone already hasnt clearly stated it yet, the first set of sensors are in the manifolds, not the midpipe.
In 99-04 ALL 4 sensors are in the Midpipe. 94-98 are the years that have the first pair in the manifolds.
