Synthetic Oil
Old Sep 12, 2003 | 12:44 AM
sanitarium16's Avatar
sanitarium16
Default Synthetic Oil
I have a 98 mustang with about 67,000 miles. If I was to put synthetic oil into it would it cause any serious problems. I have heard that it causes leaks because of its effects on gaskets. What do you recommend. Is synthetic that much better?</P>
Old Sep 12, 2003 | 01:00 AM
Kidrosey's Avatar
Kidrosey
I started putting synthetic in my 93 after about 100,000 miles and I have never had any problems with it (unless you consider my starter and alternator going out in the same week) but that has nothing to do with oil.</P>
Seriously, I'v been running synth for over 90,000 miles and as far as I can tell it has been nothing but an advantage.</P>
Put a K&amp;N filtercharger on it with Castrol Syntec and you will feel the difference.</P>
Old Sep 19, 2003 | 06:18 PM
steedaq's Avatar
steedaq
I also have 98 v6 mustang and I use synthetic without any problems. I was told however, not to go back and forth on oil like one oil change use synthetic and the next oil change use conventional oil. You should be fine. I could tell a difference in engine start up and cooler engine temperatures.
Old Sep 19, 2003 | 07:04 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
The sooner you change the better, unless your burning oil lol
wraith777
Sep 28, 2015 10:49 AM
belam
Oil and Oil Related Topics
Sep 23, 2015 11:29 PM
Demodulates
Sep 18, 2015 11:14 AM
IronRaptor
Sep 9, 2015 08:10 AM
kevsgt
Sep 9, 2015 06:20 AM
