eaton m112
ORIGINAL: 03sixbanger
here is everything i bought for $1375
2003 Cobra Supercharger (with 6k on the blower) with 2.93 Metco Pulley and Stocker pulley (3.65)
Throttle Body
03/04 Cobra TPS Sensor
Throttle Body bracket
Plenum
Idlers
All 8 Injectors (39lbs blue) (only 4k miles on them)
Focus Fuel Pump
MAF with Stock intake system down to the paper filter and K&N filter(4k miles on them)
Custom 3" high, upper plate for the Supercharger to the V6 manifold
Autometer Guages (Vac/Boost,A/F Ratio,Water Temp) with Dual Guage Pod and Single Steering Column (seperate,add 115)
Xcal-2 Tuner
All bolts for the supercharger and the Supercharger oil and Gaskets for everything on the supercharger is included. (120 dollar value)
Throttle Body
Plenum
Idlers
Focus Fuel Pump
Xcal-2 Tuner
Throttle Body
Plenum
Idlers
Focus Fuel Pump
Xcal-2 Tuner
Throttle Body
Plenum
Idlers
Focus Fuel Pump
Xcal-2 Tuner
You want to at leasst run a good cat back with any forced induction system.
As for the power amount on any given situation.... we are seeing between 15-18 hp per psi with this set up. Nobody is running an intercooler at this point, and we haven't seen the need for it yet. Nathan is working on making the Cobra IC work, but it's going to mean an even taller set up. I used an NX set up to cool mine at first, but got a little power happy.
