*FIXED* Odometer not working
Old Aug 17, 2007 | 01:41 PM
GlockPants's Avatar
GlockPants
Default *FIXED* Odometer not working
My odometer and trip. stopped working the other day. This sucks because my fuel gauge isnt that accurate and I used my trip. to figure when about I needed some gas. Anyone else have this happen? And did you get it fixed?
Old Aug 17, 2007 | 05:55 PM
tychotb's Avatar
tychotb
Default RE: Odometer not working
same thing happened with my 97 a few days ago, havent gotten it fixed yet, it -does- suck tho
Old Aug 17, 2007 | 06:29 PM
Verado's Avatar
Verado
Bad sensor..?
Old Aug 18, 2007 | 12:29 AM
GlockPants's Avatar
GlockPants
Only thing I can think of is I might have done something when I changed the oillast which was incedenly when I noticed it not working. But the only thing I did out of the ordinary was remove the aftermarket alarm horn and cut off some random wire that was coming from the firewall that was not connected to anything.
Old Aug 18, 2007 | 08:48 PM
GlockPants's Avatar
GlockPants
Default RE: *FIXED* Odometer not working
So I figured out what the problem was. Turns out the odometer assembly works a lot like the rear axle. The speedometer has a small motor connected to it that has a drive gear that is similar to the pinion in the rear end. The pinion spins a larger gear that resembles a ring gear and from there is rotates the odometer contraption. Anyway, the teeth on the ring gear part were stripped off, so as you can imagine, if you destroyed your rear diff. you wont move. Lucky for me, I had a spare gauge cluster, so I just swapped out the damaged part.
Old Aug 18, 2007 | 09:33 PM
moontangsdad's Avatar
moontangsdad
sweet at least it wasnt your rear end [sm=happy046.gif]
-Chad[aka moontang] (not dad)
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
mungodrums
Oct 7, 2015 04:01 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
