Need some advice.
Old Aug 18, 2007 | 05:24 PM
Sickspackstang's Avatar
Sickspackstang
Default Need some advice.
I have a 98' 3.8L, T5 Tranny.
My car started giving me problems. When I would put the car in first gear, I could release the clutch without moving. The car would only start moving when I revved the car to about 4k RPM. I could smell the clutch burning. I checked to see if the clutch cable was intact and working properly, everything seemed fine. I tried again wouldn't move til 4k RPM again only this time the clutch burned out.
Right now I am replacing the clutch and before I finish up with that I was wondering if the problem would still be there because of another part.
Any input/help is greatly appreciated.
Old Aug 18, 2007 | 05:28 PM
Sickspackstang
Default RE: Need some advice.
When the car did start moving it was very slow starting. And when I was in 2nd and 3rd gearand I floored it while doing about 35-45 MPH. The car would just over rev as if an automatic transmission was slipping and the car would slowly pick up.
Old Aug 18, 2007 | 05:31 PM
jthorn9's Avatar
jthorn9
The Godfather
Don't forget to have the flywheel resurfaced. I'm willing to bet the problem was between the clutch and flywheel and or a bad bearing. Just have things looked over and you should be good.
Old Aug 18, 2007 | 05:42 PM
Sickspackstang
I had the new clutch put in not too long ago and they had resurfaced it do you think I should still have it resurfaced? also where would i go to get that done? and do you have and idea of how mcuh I should pay for a resurface?
Old Aug 18, 2007 | 05:43 PM
jthorn9's Avatar
jthorn9
The Godfather
If it's been resurfaced then no problem, but I'm confused, it's doing the problem after the intall?
Old Aug 18, 2007 | 06:06 PM
Sickspackstang
Sorry for the confusion, I meant that the clutch that just burned out was installed about a year ago or so and at that time the shop either resurfaced the flywheel or installed a new one.
Old Aug 18, 2007 | 07:09 PM
Sickspackstang
Anyone have any input on the flywheel situation?
bryan616fl
Jan 25, 2019 09:07 PM
cbird1177711
Sep 2, 2015 04:12 PM
cedarmn
Aug 28, 2015 09:51 PM
