Old Feb 6, 2005 | 05:27 PM
MN1987's Avatar
MN1987
Default .
could i replace a 3.8 engine for a 5.0 on a 1995 mustang v6?
Old Feb 6, 2005 | 05:45 PM
2001_SaleenS281_08's Avatar
2001_SaleenS281_08
Default RE: .
yes but you will need a new ECU and stuff to go with it
Old Feb 6, 2005 | 07:59 PM
MN1987's Avatar
MN1987
Default RE: .
what kind of other stuff? transmission?
Old Feb 6, 2005 | 08:04 PM
ZachW04Stang's Avatar
ZachW04Stang
Default RE: .
You will need new wiring harnesses for the ecu most likely. You may be able to keep the same transmission, but you will probably need a new bellhousing.
Old Feb 6, 2005 | 08:09 PM
MN1987's Avatar
MN1987
Default RE: .
aight thanks
Old Feb 8, 2005 | 08:28 PM
matthockey32's Avatar
matthockey32
I ♥ Acer
Default RE: .
it is not worth it. the 5.0 only made 215 chp. with a blower you will blow them away, no pun intended
