valve question
Old Aug 25, 2007 | 05:41 PM
eddiev22's Avatar
eddiev22
Default valve question
I know that my engnie (02 5spd) is a 3.8L 2v engine, is it possible to make a 2v a 4v? i dont know if thats a stupid question because i don't know much about it, but what differences/gains would you see if it is possible?
Old Aug 25, 2007 | 05:45 PM
Daytripper540's Avatar
Daytripper540
Default RE: valve question
Doesn't it have to do with the heads? I'm talking outta my *** here..
Old Aug 25, 2007 | 05:48 PM
mooses's Avatar
mooses
no. You need a drop though
your sig is huge
Old Aug 26, 2007 | 05:28 PM
Blainestang's Avatar
Blainestang
When people say "2V" when referring to GTs, they're meaning 2 valves per cylinder, and technically, the 3.8L V6 has 2 valves per cylinder as well. However, the GT (as well as any other Modular motor Cobras/Machs/etc) engine is of a "Overhead Cam" design, while the 3.8L's (as well as the production 5.0's) are of a "Overhead Valve" or "Pushrod" design.
Overhead Cam (OHC) = Cams are located ON the heads and open the valves from there. If they have one cam per head (for a total of two on V-configuration engines [2V per cylinderGT's, 3V per cylinderGT's]), they are more specifically called "SOHC" (single overhead cam), and if they have two cams per head (for a total of 4 on V-configuration engines [4V per cylinderCobras/Mach 1s].
Overhead Valve (OHV, Pushrod) = ONE cam is located in the block, which pushes the lifters, which push the pushrods, which push the rockers, which then open the valves. MOST pushrod engines have 2 valves per cylinder (1 intake, 1 exhaust).
Old Aug 26, 2007 | 05:32 PM
jthorn9's Avatar
jthorn9
The Godfather
In short, yes you can make your engine a 4 valve, but you'd need a wallet the size of the grand canyon to do so. In short, it's cheaper to get a 4V V8 than it its to make a 3.8LV6 a 4V.
Old Aug 26, 2007 | 05:49 PM
Blainestang
ORIGINAL: jthorn9
Haha... Guess I forgot to answer the actual question
The overall point was that it's not just the heads that make the difference. 4V Cobras have an entirely different valvetrain/cam setup than the 3.8. Everything is possible with enough money, but if any of us had that kind of money, we probably wouldn't be driving V6 Mustangs to begin with
Old Aug 26, 2007 | 06:48 PM
LilRoush's Avatar
LilRoush
Oh come on, it's not like it would be THAT much to addacam with double the lobesto the middle of the block,redrill added runners for the extra pushrods, custom cast your own heads to be 4V, set up a completely prototype valve train and all for less than a 20 hp total gain.
Old Aug 26, 2007 | 07:04 PM
Blainestang
ORIGINAL: LilRoush
Sounds simple enough
Old Aug 26, 2007 | 10:02 PM
jthorn9's Avatar
jthorn9
The Godfather
And expensive enough.
Old Aug 26, 2007 | 10:25 PM
eddiev22's Avatar
eddiev22
so the extra valves to each cylinder only pay off when you have a 8?
