NEED SOME HELP
ANYONE with a 99????? I need some help, I do not have a manual with mine, and I need to know which fuse in the power distribution box is the Fuel Pump?? Can someone help me out please. Keep in mind that I dont have a 6cyl anymore, but I think it should be the same?????? If anyone can help let me know?
Thanks a bunch
wskygrl
Thanks a bunch
wskygrl
ORIGINAL: Daytripper540
A fuel pump...is not....a fuse...?!?
And doesn't the fuse box cover have a chart on it? Even if it doesn't, are you replacing a blown fuse. If so, just look for the blown one. Pull them out one by one and you'll eventually find it.
Thanks, but I found the fuse, it is number 14 in the power dist. box.... I needed to find it as I had to recalibrate the speedo due to 4.10 rear end and the performance chip that we put in it, and to complete it we had to make sure the fuel pump fuse was removed before we hooked up the tuner...... ... Thanks for your help... ..
