another problem
Old Aug 30, 2007 | 07:01 PM
raz54's Avatar
raz54
Default RE: another problem
It could be low on gear oil but if some one has recently put in new gears and didn't do it right they could be making the noise. Get the rear in the air (on jack stands) so you can run it and see if that's where the noise is coming from.
Old Aug 30, 2007 | 08:16 PM
98Ga's Avatar
98Ga
do you have a cai?
Old Sep 4, 2007 | 08:46 PM
lpdizzydawg's Avatar
lpdizzydawg
ORIGINAL: xX98StallionXx
Sounds like exhuast. Have u checked under ur car out ever? Do you have duals? Could be a bad hanger etc... Maybe your muffler is going to fall off...
i know its not the exsaust i have dual roush style pipes
Old Sep 4, 2007 | 09:50 PM
stangant's Avatar
stangant
i have had the same prob. it was low power stearing fluid, i fixed the broken line, filled the fluid and it stoped the noise.
Old Sep 6, 2007 | 07:35 PM
lpdizzydawg
ORIGINAL: stangant
i know its not the power steering fluid because i toped off all the fluids under tha hood when i got tha car
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
