zex help!
Old Sep 7, 2007 | 08:42 PM
lexo_usa's Avatar
lexo_usa
Default zex help!
hi everyone! could anyone tell me how can i set up shots on zex wet kit? like if u have 55 shots and u want to have 75 or 100 how can u change it?
thanks
Old Sep 8, 2007 | 01:35 AM
SilvrStang's Avatar
SilvrStang
Default RE: zex help!
i believe its by dyno tuning only , but if ur gona up it up more then 75 shot u might wana upgrade the fuel pump and d injectors
Old Sep 8, 2007 | 02:30 AM
Willem_Black's Avatar
Willem_Black
You can change the shots by changing the jets in the nozzle. Simple as that. You stocksetup should be fine for a 75 shot. You're not using a dry kit which relies on the injectors anyway, you are pulling fuel directly out the rail (or at least you should be) from the pressurized line via a second solenoid. Just read the manual on how to change the jets. Literally takes 3 minutes to do.
Old Sep 8, 2007 | 07:10 AM
superdavid's Avatar
superdavid
If you have a stock bottom end, I wouldn't hit it with anything more than a 75 shot...
eclipsegt
Mar 11, 2008 01:46 PM
BRENSPEED
Nov 16, 2005 03:05 PM
eclipsegt
Aug 20, 2005 05:01 AM
ricekiller2003
Jul 15, 2004 12:30 AM
VicsGT
Oct 14, 2003 01:41 AM
