99-04 Computer Problems?
Old Sep 8, 2007 | 09:50 AM
akinahs's Avatar
akinahs
Default 99-04 Computer Problems?
Does anyone know if the computers on the 99-04 have mass problems--I mean was there a recall or notice from Ford that there were issues? I know my computer needs to be flashed, but Ford is charging as much to do the deed as it costs to buy my own tuner (and before anybody tells me to buy my own tuner, money is definetly an object...an object I can't find). I heard (just once) that the '03's were having random computer problems, but I can't find anything to back that up. My neighbor just wrecked his '02 V6 () and he offered to give me his...but I don't want to go through that if I'm going to end up with the same problems.
Old Sep 8, 2007 | 10:51 AM
laserred02's Avatar
laserred02
Default RE: 99-04 Computer Problems?
never had problems with my computer and I put 90k miles on my 02 before i traded it in
Old Sep 8, 2007 | 01:09 PM
akinahs's Avatar
akinahs
Thanks lasser [:'(]...has anyone had problems with their computer or am I the only luck b1tch out there? In case it helps, I found out from Ford that I have this problem when I noticed a rough idle, needles on all meters would go from 0 to top end when I crank the engine, RPM's would bottom out and car would cut off when I push the clutch in. I changed sparks/wires, air filter, oil & filter, checked the fuses, seafoamed, and had codes run (which came back with nothing) so I took it to the Blue Oval boys. I've got an '03 5pd coupe with about 75k, I got it with 4 miles on it.
Old Sep 8, 2007 | 02:53 PM
laserred02's Avatar
laserred02
sounds more like your idle air control valve than the computer.i would say before you get raped take off the IAC, and clean the **** out of it with carb cleaner, also clean the throttle body. see if that helps. The IAC usually won't throw a code but will present with symptoms similar to what you describe. and if worse comes to worse it is only $45 at the auto parts store.
good luck. btw i've been on this site for awhile and have never heard of a computer problem, i have however heard of lots of people with dirty or worn out IAC valves. best of luck.
Old Sep 8, 2007 | 04:06 PM
akinahs's Avatar
akinahs
Now that's news I can use! I'll try that, thanks man!
EZFEED
May 5, 2016 08:54 PM
firecoyote
Sep 27, 2015 02:37 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
