Difference between single and split port
Old Sep 18, 2007 | 11:31 PM
crash's Avatar
crash
BrandofPoop
Default Difference between single and split port
Alright, so i wantt o know whats the difference between a split and single port, i know i have a split port, but whats the difference and what are they?
Old Sep 18, 2007 | 11:56 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: Difference between single and split port
Single port: Single set of small runners in the upper intake, air enters the TB, travels to the back of the manifold, then is sucked into their ports, then on itsway to the lower intake
Split port: Dual set of high flow runners/ports. Air enters the TB, travels down a wide port, to the top of the intake, then the air is split down two large ports then travels down those ports and air is sucked in from that port and goes on it's way to the lower intake
Old Sep 19, 2007 | 04:06 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
damn i wish my engine looked that clean!
Matt
Old Sep 19, 2007 | 08:29 AM
Weeman's Avatar
Weeman
...Amen
Old Sep 19, 2007 | 12:27 PM
Zyth01's Avatar
Zyth01
How difficult is it to switch over to the split port intake if you have the single? Or is it completely out of the question without major engine work?
Old Sep 19, 2007 | 04:50 PM
jthorn9's Avatar
jthorn9
The Godfather
Not difficult at all, just requires a lot of time, and a little cash. There are split port intake swap kits out there, but to make a long story short, you need everything that sits ontop of the engine, minus the cam, so that's heads, intake, gaskets, wiring harness, and a few other things.
Old Sep 19, 2007 | 04:51 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: Matts 85 LX
Matt
Thanks, that was me and hotrodsnbooz from "back in the day".His engine bay was cleaner, but mine wasn't too bad.
Old Sep 19, 2007 | 06:28 PM
Zyth01's Avatar
Zyth01
ORIGINAL: jthorn9
So, unless I find a wrecked 99-04 v6 nearby this is probably out of the question for my girlfriends car
Old Sep 19, 2007 | 09:17 PM
jthorn9's Avatar
jthorn9
The Godfather
No, as I stated, you can find the parts online from a couple of undisclosed locations, however it is a mod that should be done "properly" for maximum gains, and by that I mean porting/polishing.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
