need some help
Old Sep 26, 2007 | 05:24 PM
kcjh23's Avatar
kcjh23
Default need some help
okay so I was driving to class this morning and i noticed that the radios power kept surging when i would change stations and stuff but i didn't really think anything of it.. then about 10 mins later or so my car completely shut off while i was driving off of the freeway.. the electrical, engine and everything went dead.. fortunately it restarted a few seconds later and didn't do it again.. also lately its been hesistating a bit to start up.. anybody have any ideas what it could be?
Old Sep 26, 2007 | 06:45 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: need some help
Sounds like a charging issue, either battery or alternator. Run to a parts store and have them test it out for you.
Old Sep 26, 2007 | 07:01 PM
raz54's Avatar
raz54
Beside what Ryan said I would check the battery connections. A loose or corroded connection can cause the problems you had.
Old Sep 26, 2007 | 09:03 PM
kcjh23's Avatar
kcjh23
yeah.. i think i'm going to change out the connectors and battery cables cus their kinda old.. and seeing as how the battery is just shy of a year old i couldn't think it would be anything wrong with that.. as far as corrosion goes tho the terminals are completely clean
