Short Shifter!!!
Old Feb 19, 2005 | 03:35 PM
Chanedeezy4106's Avatar
Chanedeezy4106
Default Short Shifter!!!
Do short shifters really help out a lot during a race????
Old Feb 19, 2005 | 03:40 PM
Chanedeezy4106
Default RE: Short Shifter!!!
How do you get the picture of your car to show up in your signature???
Old Feb 20, 2005 | 02:18 AM
DaGGer's Avatar
DaGGer
lol you have a picture in your sig...and i would say that it does help out...my friend has a gold with a short shifter and he says its ****ing so much better
Old Feb 20, 2005 | 04:18 AM
MACHJUAN's Avatar
MACHJUAN
it helps alot dude if your thinking of buying go with a b&m trust me on this one. Your throws will be shorten by 35%. for now just double clutch it's cool
Old Feb 20, 2005 | 11:00 AM
DaGGer's Avatar
DaGGer
well there are other ones but the b&m is suppose to be the best
Old Feb 20, 2005 | 03:10 PM
Chanedeezy4106
Tight i will look into the B&M shifter how much do those run?
Old Feb 21, 2005 | 03:45 AM
BaltimoreStreetMods's Avatar
BaltimoreStreetMods
these shifters will get ya done!!!!
The short throw is a lot better for racing, and they are more durable.... if you are pounding the stock shifter, it will wear out fast. TORE my STOCK shifter up in about 6 mos ( a lot of track time and street too lol)
UPR makes a great shifter:
http://www.baltimorestreetmods.com/Shifters.html
These are all made from aircraft aluminum, and are adjustable so you can set em where ya want em. andBTW, many of the shifters on the market today are MADE BY UPR, in bulk, and sold to other companies who rebox em and sell em for twice as much....
B&M = $193.... UPR = $129
"UPR shifters are made
from the highest quality materials available, features a (Lifetime Warranty).
-Offset preload springs find 3rd gear for you, so you won't miss ever again!
-Smooth, Precise shifts
-Stainless Steel Shaft & Pivot Ball making it the strongest on the market unlike the competition
-Won't rust like competitors cheap mild steel nickel plated design
-Adjustable Shifter Stops to prevent shift fork damage
-Infinite Position Adjustable Height and angle, for smooth, fast, comfortable shifts
-Heavy Duty Construction
-No welded or cast parts
-100% CNC Machined from 6061 T-6 Billet Aluminum
-Utilizes a higher ratio pivot mechanism for smooth and precise power shifting
-Made in the USA
-Fits all factory and Aftermarket shift ***** 12mm.
All Blu Thunder shifters are constructed from the best grades of aluminum. We are also the only
manufacturer to make their center shaft out of Stainless Steel and use the highest quality
components without trying to take you to the cleaners at checkout time.
Blu Thunder shifters are used by more winning NMRA, FFW, WFC and class leaders to make it
the most trusted shifter in any application from street use, drag racing or road racing time and
time again."
Old Feb 21, 2005 | 09:30 AM
Chanedeezy4106
Thanks for the info I will be looking into the UPR!!
firehorse02
Nov 16, 2015 11:28 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
