precision engines
its from the stock 3.8 block and its strocked to a 4.2l i think with a 9.5/1 compression ratio i have a spec sheet but it doesnt want to copy and paste right maybe i can add it as an attachment
i did ask on a diff. forum and my window of oppurtunity was very small so i couldn't to much research... and i just wanted to know if anyone had any good or bad experiances with them?? what would stage 2 ported heads add to performance??
heres a spec sheet from precision engines, i got stage 2 porting for free:
Please review the following quote and specifications to your custom-built performance longblock:
3.8L block bored, honed, decked and align honed
Speedpro performance camshaft;
204/214 @ .050
.470 lift
112 lobe center
New Durabond performance cam bearings
Balanced rotating assembly
Reground “3.75 stroke steel crankshaft
Resized rods with ARP® rod bolts
New King® performance bearings
Speedpro® hypereutectic performance pistons with Molly® rings
9.5 to 1 compression ratio
New Melling® performance timing set
New Melling® performance high volume oil pump
Cylinder heads
1.90â€/1.50†stainless steel valves
100 lbs valve springs
New head bolts
3 angle seats
Bronze guides
Positive seals
New push rods and stamped rockers
New gasket set
1 year unlimited mileage limited warranty
Painted Ford Black or Grey with aluminum heads
• Stagel porting add $250.00 Stage2 add $450.00
• Oil pan, front cover, balancer and intake available at extra costs.
• Price 1999.95 Exchange or core charge of $300.00 plus shipping
204/214 @ .050
.470 lift
112 lobe center
Cylinder heads
New head bolts
3 angle seats
Bronze guides
Positive seals
New gasket set
